B16 crank and rods in a B18c block??
B16 crank and rods in a B18c block, first off is this possible??
second off could you use B16 rods in a gsR block with a gsR crank??
what kinds of set ups would this make with a B16 head
B18c1 block+b16 crank,rods,pistons=?
B18c1 block+B18c1 crank+B16 rods and pistons=?
Re: B16 crank and rods in a B18c block?? (mrbsponge)
B16 rods and crank will bolt into B18c,BUT the piston will be about 5/16" down in the hole.You need a longer rod to make this work.The B16 rods are too narrow and short to work on a gsr crank.Only reason to use a B16 crank is if your limited by rules to 1.6L.
Glenn
Glenn
if you use a CTR rods, this will work...
I was pretty sure that that's all a CTR was, a B16 crank in a ITR block... and i know CTR rods are very long, so it made sense to me.
-Mike
-Mike
Re: (NJIN BUILDR)
with a b16a block what would be best to use to get the most power? ls crank with b16 rods and ctr pistons or b16 crank with b16 rods with ctr or itr pistons ?
