What gears are interchangeable?
Old Jan 7, 2005 | 12:28 PM
crxhybrid85's Avatar
Default What gears are interchangeable?
In the b series transmissions, can you swap out gears and diffs at will or are there differances? I need a cable tranny, and will probably get a b16 or a ys1 (which is the one I really want). If I get the ys1 first and second are short enough for me, but I want to put in a 4.7 Type R final drive if possible, and a OEM lSD. Same for the b16 (y1 right?) but I think I would also switch the first two gears to GSR or Type R gears if I can.
Old Jan 18, 2005 | 12:48 PM
Default Re: What gears are interchangeable? (crxhybrid85)
Bump, cause I need to know
Old Jan 18, 2005 | 07:45 PM
acy76's Avatar
The YS1 is the transmission you want. It's the only cable-clutch unit compatible with later hydraulic-clutch innards -- which means you can swap any hydro b-series gearset or diff in with little or no modifications.
Here are a couple of threads to get you started; search too, as there have been lots of discussions on the topic.
https://honda-tech.com/zerothread?id=943822
https://honda-tech.com/zerothread?id=1026107
Old Jan 19, 2005 | 06:48 AM
Default Re: What gears are interchangeable? (acy76)
Awesome, thanks
BrowNKiD
Transmission & Drivetrain
Apr 12, 2011 11:26 AM
JDM_rolex
May 20, 2007 07:31 AM
JDM_rolex
May 17, 2007 01:44 PM
GSRCRXsi
May 20, 2005 08:00 PM
GSRCRXsi
