EF/SI Sub-Harness
Old Jan 2, 2005 | 10:56 PM
TeaminlineB16's Avatar
Default EF/SI Sub-Harness
Where in the world does the Hasport Sub-Harness for B16 in CRX HF (89) Go?! HOW AND WHERE DOES IT GO?! i need pictures or some intructions....im confused.....i have everything ready and this is the only hold up....the wiring
Car:1989 Honda CRX HF
Engine:B16 JDM & OBD0
Just in case this info works......
Old Jan 3, 2005 | 09:39 AM
locash's Avatar
Default Re: EF/SI Sub-Harness (TeaminlineB16)
The harness runs from the extra sensors (VTEC Solenoid, VTEC Oil Pressure, Knock Sensor, 2nd O2) to the ecu at the correct pin locations. It's pretty straightforward..
They come with instructions when you order them for easy installation.
Old Jan 3, 2005 | 09:46 AM
chad's Avatar
Moderator
Default Re: EF/SI Sub-Harness (locash)
basically you just hvae to get the wires threw the firewall....not really an exact place just get it threw near the fuel filter....down about a foot there is a gromet there you can push out
Old Jan 4, 2005 | 07:06 AM
Default Re: EF/SI Sub-Harness (chad)
ok, so i install the HF harness on the motor and then hook it up right? Then i connect the harness to the V-tec sensors? Then to the ecu? That seems like a no brainer......correct me if im wrong
Old Jan 4, 2005 | 07:08 PM
locash's Avatar
You've pretty much got it, install the HF harness onto the b16, and then the hasport subharness, drop the motor in, run the hasport subharness through the firewall and plug the pins in at the correct locations at the ecu plugs, and you're done..
Old Jan 5, 2005 | 05:48 AM
alright cool i got the sub harness figured out.....But about the HF harness....it plugs up to the engine pretty much the same right? I wont need to extend wires?
wickedEFguy
Apr 8, 2004 02:08 PM
awooooo
Nov 11, 2003 03:16 AM
whitemike1644
Sep 13, 2003 05:58 PM
EGTeK
May 17, 2003 10:27 AM
pdiddyparsons
Mar 25, 2003 02:01 PM
