swap problems
Old Dec 25, 2004 | 08:29 PM
honhatchisbak's Avatar
Default swap problems
so i blew my old set up with turbo cause of fuel and timing problems, so got a b18c gsr block and b16 head on car, with turbo set up on the but havnt ran the charge pipe yet cause i want to get the car tuned first, well when i try to start car up it turns on then dies right after, keeps doin it for a good while, if car turns on and i push gas will die right away, when car finally turns on and stays on its pretty much ok, just that the idle jumps real low and goes bak to normal does this alot, it throws code 6 which is ect water temperature sensor, not sure if this has anything to do with why my car is running like that, the block is 97 gsr, head is 00 b16, its in my ek hatch, with obd2 to obd1 jumper harness and chipped ecu for now, if anyone can help let me know, could it be the timing is off, i drove the car home and around and it runs ok, just havnt got on it or anything didnt want to mess anything up, thanks
Old Dec 25, 2004 | 09:26 PM
smart monkey's Avatar
Default Re: swap problems (honhatchisbak)
try connectin the charge pipe and see what happens
Old Dec 25, 2004 | 09:39 PM
Default Re: swap problems (smart monkey)
so i had a friend just come over and he fixed all the problems all it was that i had to plugs connected wrong, something so simple i just overlooked
dE.fUsEd
Nov 14, 2011 07:49 AM
UndisputedH22a
15
Apr 27, 2010 03:56 PM
import810
Sep 2, 2007 12:31 PM
XJamesX
Sep 23, 2006 07:40 AM
fabe85
Jul 17, 2006 11:53 AM
