When doing an engine swap....
Old Dec 23, 2004 | 06:08 AM
B18Redline's Avatar
Default When doing an engine swap....
Does all of the engine block coolant get drained out?
Old Dec 23, 2004 | 07:07 AM
ExiledinIN's Avatar
Default Re: When doing an engine swap.... (Redline07)
You should drain the coolant from your existing engine as you will need to disconnect it from the radiator.
Old Dec 23, 2004 | 07:49 AM
SpeedFreak77's Avatar
Simply put.....YES.
Old Dec 23, 2004 | 05:43 PM
The Clash's Avatar
For the most part, yes you should drain as much as possible unless you want a mess on your hands when taking it out.
Old Dec 23, 2004 | 09:38 PM
triple_s1x's Avatar
Default Re: When doing an engine swap.... (The Clash)
quick way to drain the block is to open up the plug on the front of it...
ratfongbips
Feb 16, 2018 08:24 PM
Jeff Lebowski
Nov 14, 2016 05:02 PM
DIRTYsouthBB6
Jul 13, 2006 09:51 AM
whoa its len 2
Jul 17, 2003 09:47 AM
