B16A O2 Sensor Question
Old Dec 29, 2004 | 05:47 PM
Type_RS_59's Avatar
Default B16A O2 Sensor Question
There is hardly any O2 sensor info in the search so here it goes. I recently picked up a '95 Civic LX Sedan with a '95 JDM B16A in it and it's running a chipped P28 ECU. It still has the LX oxygen sensor in it so it is throwing a CEL. I need to pick up a new one but I'm not sure which one. I can get a good deal on an NGK for a GSR from a friend that never used it, but the part # is different from that of a '95 del sol VTEC, which I figured would be the closest match. Is the only difference the length of the wires? The car has a Ractive header on it if that makes any difference.
Thanks
Old Dec 29, 2004 | 06:14 PM
eda6's Avatar
Default Re: B16A O2 Sensor Question (Type_RS_59)
I use a 93 acura vigor o2 sensor for my b16 and my back up is from a 94 accord.
Any four wire o2 sensor will work.
Old Dec 30, 2004 | 08:44 AM
Type_RS_59's Avatar
Default Re: B16A O2 Sensor Question (eda6)
Thank you eda6, I thought so but I wanted to be sure.
Contender25
17
May 3, 2006 09:04 PM
asiansgoweeee
Oct 19, 2004 06:22 PM
kagegod
May 10, 2004 03:01 PM
zerofighter777
Feb 13, 2002 10:12 AM
