Need help on the ITR manifold in a B16?????
Well i have just put the itr mainfold in my B16, and just now started the ignition or started the engine. and have a problem. My engine sounds like it's leak, and rpm is at 2000 when i start the engine.
*<U>What i used</U> is the stock intake manifold gasket, the b16 throttle, and the B16 fuel line.
*<U>WHat happen?</U> it leaks from the throttle body, and RPM is @ 2000
Re: Need help on the ITR manifold in a B16????? (eg_type_r93)
Well i felt that it leaks and the engine keeps on reving highso thats why i went to get a new intake manifold Gasket & throttle gasket and put my stock back on. So i Return the Type_r manifold back.
Re: Need help on the ITR manifold in a B16????? (egs4life)
well i decided to not put it on no more, and plus i found out that the b16 P30 help out more then the itr. Why? because there's a book that shows the dyno on it.
95BlkGSR
04-21-2009 06:29 PM
crazyguy
01-12-2008 05:05 AM
dohcMONSTER
04-22-2004 02:59 PM
