My H22A!!
Banned
Re: My H22A!! (JakeIsCool)
Note: I do not have the motor yet. This one is being saved for me at the warehouse until they have all of the other motors ready and lined up.
My plans for the H22:
Injen short ram intake
Bored Throttle body to 65mm(Maxbore)
Skunk2 Intake Manifold
Aggressive Port N Polish(Portflow or King Motor Sports)
3 Angle Valve Job and head resurfacing(" ")
AN-R Header feeding into a 2.25 inch exhaust
ClutchNet Clutch kit
Re-surface flywheel
Lighten flywheel on a brake lathe
Prelude axles
New spark plugs-plug wires-distributor cap and rotor-water pump-timing belt
No A/C
No Cruise Control
New gaskets-all
Some new fresssh oil and tranny fluid- radiator fluid
UBERDATA!!- Thanks to Atheist-Mike
Thermostat from Mugen- Op Temp 68 Degrees
Fan swtich from Mugen- activates fan at 80 Degrees
Re-surface flywheel
Prelude axles
No A/C
No Cruise Control
New gaskets-all
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">
**** that, buy my Imagine Engineering header... Brand new and I'll do it for $500 shipped. And it's a sexy, powder coated black by IE.
https://honda-tech.com/zero...53619 ---dyno proven by a HT member for 17WHP!!
But on a less shameless note, sounds good. H22 Civics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">Thanks Luke
Mine looked better J/K Looks good, enjoy.
Ditto
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">96 Accord, I orig wanted and IE header but they wont fit my chassis.</TD></TR></TABLE>
Ahhh, oh well....
hahaha, H22 Accords
Ahhh, oh well....
hahaha, H22 Accords
Banned
Re: My H22A!! (RotiEatter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RotiEatter »</TD></TR><TR><TD CLASS="quote">Ahhh, oh well....
hahaha, H22 Accords </TD></TR></TABLE>
****** Right
****** Right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">AN-R Header feeding into a 2.25 inch exhaust </TD></TR></TABLE>
AN-R collector is 2.5". Why you going to run 2.25"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JakeIsCool »</TD></TR><TR><TD CLASS="quote">Lighten flywheel on a brake lathe</TD></TR></TABLE>
If you are resurfasing the flywheel, just do that, not "lighten" it. Aftermarket flywheels put most of the weight of the flywheel in the center. Why do they do this? It takes less work to move weight that is close to you, then away from you.
Banned
Re: My H22A!! (turbogixxer)
Guess i didnt really think about that, the collector on my greddy header is 2.25 so i have 2.25 inch exhaust on my accord right now. I have a custom bent pipe with a resonator and muffler on it so ill just have those cut out and have custom 2.5 bent. Thanks for catching that.
H_doubledeuce_A1
03-30-2004 10:05 AM
