B20 Vtec in a CRX
Old Dec 29, 2004 | 09:40 PM
SIKSI's Avatar
New User
Default B20 Vtec in a CRX
Sometime this week I will be picking up a B20 vtec and dropping it into my 1990 crx si. I will be pulling the B20 out of my friends 1990 integra and then dropping it into my crx. How difficult is this swap? How much extra wiring do i need? I believe i could use his axles how about engine mounts and shift linkage?
I was quoted by a local shop that he would do this swap for $600 total. I was hoping i could save some money and do it with some friends
thanks Jason
Old Dec 30, 2004 | 04:34 AM
The Clash's Avatar
Default Re: B20 Vtec in a CRX (SIKSI)
You'll need a B Series EF mount kit and linkage. Axles you can reuse from the Integra. Wiring won't be too bad since you have an Si but there will be a little more if you do an OBD1 conversion (highly recommended). You'll need to reuse the Si harness and add the additional wiring.
Old Dec 30, 2004 | 10:29 PM
SIKSI's Avatar
New User
Default Re: B20 Vtec in a CRX (The Clash)
Thanks the clash for the info.. Any recomendations on which Mount Kit and linkage i should use? Also is there any good sites that have good instructions on this swap?
Jason
Old Dec 30, 2004 | 11:28 PM
Plugs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIKSI &raquo;</TD></TR><TR><TD CLASS="quote">Any recomendations on which Mount Kit and linkage i should use? Also is there any good sites that have good instructions on this swap?
Jason</TD></TR></TABLE>
If I were you I would check http://www.b20vtec.com . When I started my b20vtec build I used that site. It was Very helpful. Good luck with you new toy!
Old Dec 31, 2004 | 04:58 AM
The Clash's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIKSI &raquo;</TD></TR><TR><TD CLASS="quote">Any recomendations on which Mount Kit and linkage i should use?</TD></TR></TABLE>
HASport and HCP are the only mounts most people would consider. HASport are all solid billet and slightly more expensive but are definitely worth it IMO. HCP are also very good, just don't buy any of the knock-offs because there are tons of these (Totem, Enjo, etc.). Make sure and get the linkage from the same company you buy your mounts from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIKSI &raquo;</TD></TR><TR><TD CLASS="quote">Also is there any good sites that have good instructions on this swap?</TD></TR></TABLE>
Really the swap would be no different than any other B series VTEC motor. Mounting it, wiring it up and all that is the same. Just search around here on H-T and read up on the OBD1 conversion.
honda1612
Apr 12, 2016 09:55 PM
integrakidd
Sep 3, 2006 04:24 PM
widecoupe
Jan 11, 2005 04:33 AM
1990CrxSi
21
Aug 6, 2002 05:18 AM
Blaze45
Jul 8, 2002 04:48 AM
