OBD2a Dist. on OBD2b harness
I just got done putting a 1998 GSR motor in my 1999 Civic DX, I used a 99 Civic Si engine harness so I didnt have to do any wiring. When we started up the motor we got a code 9(cylinder sensor). I am using a P28 with a Lightning Motorsports conversion harness. My engine harness(OBD2b) has 8 wires on the distributor plug and the distributor(OBD2a) has 9 wires. I thought all OBD2 distributors were the same? Any suggestions as far as what I can do, besides getting a OBD2b distributor? Thanks.
Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">there is a blue wire that is on the distributor harness, but not on the engine harness right?
if trhat is what you are seeing it is normal.</TD></TR></TABLE>
Si (99-00) have a blue (igntion output) wire on the dizzy. Like all B-series OBD2 dizzys. EXs do not.
98vtec
03-21-2008 04:28 PM
