b series cable/hydro differences?
Old Dec 23, 2004 | 01:10 PM
HamiltonRex's Avatar
Default b series cable/hydro differences?
The transmission mount on the B series cable, is it the same as the B series Hydro? Or is the transmission mount a different style.
IE. Could i swap a Hydro tranny inplace of a Cable tranny using the same transmission mount? And just use hasports conversion for the clutch...
Searched to no avail.
Old Dec 26, 2004 | 10:12 AM
fffrog's Avatar
Default Re: b series cable/hydro differences? (HamiltonRex)
the mount is completly different.
Old Dec 27, 2004 | 04:34 AM
VTECVillain's Avatar
As mentioned they are completely different. In order to use the hydro tranny in a cable equipped car (or vice versa), you gotta have the mount. There's a reason that HASport sells these as a kit with a mount.
Old Dec 27, 2004 | 09:14 AM
Default Re: b series cable/hydro differences? (VTECVillain)
Thankyou. The only problem is my mounts were put in the car back in 99' before everyone started doing swaps as much. So mounts were very expensive back then, so it isnt just as simple as bolting in a hasport mount because my mouts were re-welded.
Old Dec 27, 2004 | 12:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex &raquo;</TD></TR><TR><TD CLASS="quote">so it isnt just as simple as bolting in a hasport mount because my mouts were re-welded.</TD></TR></TABLE>
If that's the case you will probably have to make a custom mount using a stock hydro mount. I mean it's hard to say without seeing the car and knowing exactly what was done.
singledout94
Jan 30, 2010 04:40 PM
SIred91
Feb 2, 2009 09:49 AM
phatboycrxhf
10
Aug 21, 2008 12:04 PM
stwano
Aug 21, 2007 01:55 PM
90teg
Aug 1, 2005 10:32 AM
