B18c1 swap problem...mounts
Old Jan 8, 2005 | 08:41 AM
Oren's Avatar
Default B18c1 swap problem...mounts
I have a 1996 civic EX auto. Im trying to swap in a 2001 B18C1. I have no idea how to connect the top tranny mount to the frame, none of the mounts fit on there. It looks like the mounts are different between the auto and manual. Does anyone know to fix this problem, or will I have to find someone to weld me new mounts?
Old Jan 8, 2005 | 03:45 PM
usfsfirefighter0's Avatar
Default Re: B18c1 swap problem...mounts (omnic0n)
what mount r u using in the back?
Old Jan 8, 2005 | 07:21 PM
Oren's Avatar
Default Re: B18c1 swap problem...mounts (usfsfirefighter0)
99-00 si....thats not the problem...its the top tranny one.....
Old Jan 9, 2005 | 10:51 AM
locash's Avatar
You need the bracket that sits on top of the transmission from a 96-00 Civic 5 speed model..
Old Jan 9, 2005 | 03:54 PM
97civicdx's Avatar
Default Re: B18c1 swap problem...mounts (locash)
99-00 SI will work too.
Old Jan 10, 2005 | 10:15 AM
Oren's Avatar
My car before the engine came out was an automatic 1996 civic ex....The keyword here is automatic. I put in the new engine, a 5 speed B18C1. I have the 99-00 si top tranny mount, but it doesn't mount to anything on the frame.
I think what I should have asked is, are there any differences in the "frame" mounts between an auto and a manual.
Old Jan 11, 2005 | 04:21 PM
97civicdx's Avatar
So why dont you get the body side mount. It isnt that expensive.
Old Jan 11, 2005 | 04:56 PM
Oren's Avatar
Default Re: B18c1 swap problem...mounts (97civicdx)
Care to explain thsi body side mount....?
I went to H-Auto, a honda supplier and I asked them. They said aside from welding something on, there is no mount that will fit there for my new manual car.
Luckily my friend has a friend who's a welder, and he welded the mount in last night.
Old Jan 11, 2005 | 10:39 PM
Go_Fork_Urself's Avatar
Default Re: B18c1 swap problem...mounts (OmniB18C_EK)
Goodluck i have the same car and motor
Old Jan 12, 2005 | 12:55 PM
97civicdx's Avatar
The 96-00 Civic's have the rubber bushing mount attached to the chassis and the engine gets the matching bracket. Fifth gen civic's and tegs are opposite.
Old Jan 12, 2005 | 03:02 PM
Oren's Avatar
I'm still confused....it looks from pictures that the automatic vs manual chasis have different mounts. I'll take a picture of mine, and compare it to a manual one.
Old Jan 12, 2005 | 03:37 PM
97civicdx's Avatar
try hondaautomotiveparts.com
fletch00
Dec 6, 2013 12:39 PM
KPowerSquadron
Aug 16, 2010 04:49 PM
kd97accord
Apr 29, 2010 05:06 PM
Si Integra
Mar 9, 2005 12:38 PM
fastcars
Feb 17, 2005 12:29 PM
