h22 civic hb tranny problem
Alright guys, I have a problem with my tranny. I have a usdm h22a4 block and a jdm h22a tranny with ACT 6 puck clutch. It used to grind in third gear until I put in some GM Synchro mesh and I haven't had any problems with grinding ever since. My problem now is that if I am getting on it and try changing gears fast, it wont go into 2nd, 3rd, 4th, or 5th. Its weird it doesn't grind at all it just doesn't let me go in. If I am driving normal it shifts fine. If I get on it and try to shift it won't go in so I have to let off the gas still trying to push it in then it will go in then punch it again. It really sucks. It's killen my times at the track or whenever I run anyone. Any info would be great. Thanks.
Re: h22 civic hb tranny problem (h22Hatchy)
Sounds like it could be with the synchro's or the forks. I would probably crack open the case and look at it.
If you don't know much about tranny's, crack into a Helms manual and read into it to learn..
It looks hard, but is actually quite easy.
Re: h22 civic hb tranny problem (turbogixxer)
The shift cables are new and I checked them to make sure they are not kinked up. If it were the synchros would't it grind? I only ask because it doesn't grind at all. I will check the forks to see if that is the problem. Thanks for the help guys.
CTR-GSR
07-05-2006 01:04 AM
sinfulDB1
01-27-2005 10:15 PM
EdBoon
04-25-2004 06:02 PM
