obd0 b16 into 92 civic vx
can I use the vx distributer, injectors, ecu and wiring harness or do i have to use the si ones. what else do I have to do to get this to run i already have the motor in and everthing else done I just need to wire it any help would be gretly appreciated. thanks
Re: obd0 b16 into 92 civic vx (bmoney)
No you can't use the distributor, injectors, ecu, not to sure on the harness I'm sure you can use that. You could convert to OBD1 using the gsr distributor, injectors and ecu, since those cars are OBD1.
Serdar
04-18-2019 03:15 PM
