B16A2 in a 95 GSR??
B16A2 in a 95 GSR??
B16A2 in a 95 GSR??
Ok got a 95 GSR shell with all stock wiring under hood. Will a 99 Si motor b16a2 wire up directly with out a problem?
Can I used GSR wiring harness or do I need the 99 Si wiring.
Looking for a plug and play set up. No cutting ot splicing.
Re: B16A2 in a 95 GSR?? (97dxswap)
For the motor to be plug and play into your car, you need to get an obd1 distributor and fuel injectors. Everything else should be plug and play basically.
RC_Benjamin
03-14-2006 05:44 PM
fckmnky69
03-04-2005 09:50 PM
