B18C5 into a 92 cx auto
Ok guys... I'm in need of some help here. This will be my first hybrid car and I need some direction/advise. I'm going to be purchasing a 92 cx civic and an ITR swap. The civic is an auto so I know I'm going to have get a pedal set but what else needs to be done? I'm getting the ECU as well. I will have full access to a lift and any tool needed so the job should be easy it's all the little stuff that I'm concerned with. What harness will I need? Any little things I need to know about. Thanks all.
-Dave
-Dave
Re: B18C5 into a 92 cx auto (Dave_B)
You will need the pedal box, clutch reservoir, and hydro line and hardware all sourced from the donor 5spd car that you fine. A slave cylinder may or may not come with your swap, so you may need that as well.
The other thing that you will need is to do something about the transmission side engine mount. The automatic transmission mount bracket is different than the 5spd one, so that engine mount for the transmission will not line up. There is a mount designed for such swap that we offer.
