K20a in a EK
Old Nov 21, 2005 | 05:17 PM
JDM99Hatch's Avatar
Default K20a in a EK
i have the k20a and the hasport mounts,harness,axles, and header and hondata reflash ecu.....what all other part are required to make this swap work
Old Nov 22, 2005 | 09:31 AM
KNEEMAH's Avatar
Default Re: K20a in a EK (JDM99Hatch)
Here you go my friend : https://honda-tech.com/zerothread?id=1274311
Old Nov 22, 2005 | 07:57 PM
Gillard82's Avatar
Default Re: K20a in a EK (KNEEMAH)
that swap is crazy, aq lot more extream then my H swap
Old Nov 23, 2005 | 01:50 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM99Hatch &raquo;</TD></TR><TR><TD CLASS="quote">i have the k20a and the hasport mounts,harness,axles, and header and hondata reflash ecu.....what all other part are required to make this swap work</TD></TR></TABLE>
I suggest the following
RSX-S clutch slave cylinder (you'll need this)
custom clutch line (suja motoring)
Karcepts shifter (relocation) kit
custom fuel line set up (~6ft line, lotsa fittings, FPR, fuel rail)
might wanna replace clutch (&flywheel) depending on mileage
custom intake (Moto-C has 'em)
clips for shift linkage
shifter box
RSX upper rad hose & (99-00) si lower hose
D/B-series temp switch (w/hasport adaptor)
96-00 cx/dx/lx throttle cable
to eliminate powersteeringEP3 idler pulley & bracket & 7 rib belt 50.5" long or custom P/S lines & notched hood to keep P/S
I am also upgrading to aftermkt rad & slim fan
i would eventually get a better header (burns, hytech, DTR, RMF, R-crew)
go to http://www.k20a.org & search been covered alot
fujitsuten
K Series
10
Jul 29, 2014 04:29 PM
g0ldywang
Dec 30, 2011 08:35 AM
D-Clem
Oct 24, 2010 02:55 PM
mmk21
Dec 29, 2007 09:06 AM
BIGBLOCKEK
Sep 6, 2004 11:14 PM
