shift linkage question
Old Nov 29, 2005 | 01:56 PM
Touge Tuning's Avatar
Default shift linkage question
K i have a quick question guys, im installing a B18b1/GSR tranny into a 2000dx and i bought whats suppose to be a GSR shift linkage. Now i just went to put the new short shifter onto the shift linkage and the gap is way bigger than the bottom of the shift lever. Am i just suppose to use washers to fill in the space or do i have the wrong shift linkage? When i installed my B&m short shifter onto the same engine/tranny setup i had no problems whatsoever. BTW it has the metal rod coming off the end of the shift linkage which i dont think is on mine?
Old Nov 29, 2005 | 09:40 PM
TTT
Old Nov 30, 2005 | 07:12 AM
jdmcars.com's Avatar
Default Re: shift linkage question (scarlemthug)
Some of the aftermarket shifters are made for multiple applications. There are normally silver or gold spacers provided for the shifter.
The medal rod, if you are speaking of the piece that is on the end (towards back of car once installed), that is a weight for contershifting and better throw when shifting.
If you can, summit a picture of the linkage, you can normally tell quickly with a quick look.
Old Nov 30, 2005 | 11:15 AM
looks like this one, supposedly it was a GSR shift linkage?
Old Dec 2, 2005 | 05:38 AM
SprayinCX's Avatar
yea what the jdmcars guy said. the one we just put in we had to use spacers. we talked to the guys we bought it from and they said since the honda/acrua ones where so close they make they fit the hondas and then you use spacers for a acura. i guess it is cheaper for them to make 1 style instead of 2.
Old Dec 2, 2005 | 07:00 AM
Default Re: (scarlemthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scarlemthug &raquo;</TD></TR><TR><TD CLASS="quote"> looks like this one, supposedly it was a GSR shift linkage?</TD></TR></TABLE>
Would need a full picture of it, something to show the other end which is important. That stock shifter didn't come out of a 94+GSR for certain.
Even though the end of the picture is cut off, it looks like it probably is a B Series shiftlinkage.
It does look like something that will work, it is hard to compare with only a picture, but the picture does at least show that it is not a D Series or something completely wrong.
UrVtecIsLoud
Jul 26, 2006 07:26 PM
Crab Man
Apr 27, 2006 08:03 AM
lsvtec101
May 2, 2003 08:17 AM
hybridbmw
Jun 24, 2002 04:15 PM
