d15z2 mini me possible?
can a d15b (vtec) head go onto a d15z2 bottom end?
its an aus spec dual carby (d15z2)
i have the whole d15b vtec engine but if i can do a head swap i will
is this possible?
the dual carby actually has an ecu
i've heard problems with the d15z1 in terms of compression issues
is this the same with the d15z2?
is this possible?
hmm nobody knows anything about mini-me's?
technically the bottom end of my engine should be the same as any other d15 series right?
and i just checked the engine block to be a d15z2
it's an AUDM civic 'breeze' 1994
heres the specs
http://www.redbook.com.au/vehi...D94AK
well if no one can answer the previous question could someone atleast tell me;
shouldn't the bottom end of any d-series sohc 1.5L engine be compatible with the d15b head?
despite it being a dual carby, this shouldn't affect the bottom end whatsoever right?
heres the specs
Re: (michael_antoi)
I dont know what the compression is on the z2, but the z1 has dished pistons and the compression would be too low. Thats why most people dont use the z1 unless you would change the pistons. But if you just want to bolt the head on, it will work.
Mr_Black
K Series
11-05-2016 06:59 AM
jimakazi
10-12-2016 08:52 PM
cfk182
05-17-2005 01:35 PM
