Hybrid header question....
Old Nov 7, 2005 | 04:07 AM
Cesare1987's Avatar
Default Hybrid header question....
hey guys i was wondering if u could help me out.... im looking to buy a header for my b18c1 in my eg hatch, i've heard that i need a B16 99-00 CIVIC SI header, is this true? also wondering if i got say and dc sports jdm 4-1 header for a b16, would the header clear my oil pan on my b18???
thanks in advance guys..
Old Nov 7, 2005 | 08:59 AM
98 Spec R's Avatar
Default Re: Hybrid header question.... (Cesare1987)
The B16 Header will rub on your oil pan, it will not fit a B18C properly. I would buy a header to fit a USDM Type R Integra and it should bolt right up. A GSR header will work but there is not a bung for your O2 Sensor, since the GSR cat has the hole for the O2 Sensor. The JDM ITR header will work but it has a larger collector, 2.5", and you would need to modify your test pipe or cat to accept the larger collector. Good Luck!
Old Nov 7, 2005 | 09:50 AM
phateless's Avatar
can't he just use the gsr cat with the gsr header? or does that cause exhaust fitment issues?
Old Nov 7, 2005 | 09:59 AM
APEX CRX's Avatar
Default Re: (phateless)
USDM type R or a 96 and up GSR header (has an O2 bung)
imacoolkid
Nov 10, 2006 07:15 AM
vestalfootball72
Oct 26, 2006 10:34 AM
slow91crx
29
Jun 12, 2006 01:53 PM
beastrx
Aug 19, 2004 06:53 PM
brian.edge
Mar 25, 2002 05:27 AM
