swapped b16a1 intp eg bubble
i have a jdm 2nd generation b16a1,,,,and iam wondering if a 94-95 ls alternator will be the same as a 94-95 gsr alternator.....will it make a difference.......the gsr is 120$ and ls is 80$ .....trying to save money thanks
Re: swapped b16a1 intp eg bubble (streetsweaper)
They WILL bolt up from block to block. The difference 'probably' is the amp output. The GSR would have more electronics, requiring more from the alt. That output is only an assumption, but they will certainly bolt up.
