is the knock sensor necessary to wire up??
Old Nov 24, 2005 | 01:59 PM
civhatch's Avatar
Default is the knock sensor necessary to wire up??
the questoin is in the title, i need to wire vtec and the knock sensor, but i have misplaced the sensor and they arnt cheap so i was wonderin if there was a way around it, thanks
Old Nov 25, 2005 | 03:24 AM
Katman's Avatar
Default Re: is the knock sensor necessary to wire up?? (civhatch)
no you don't have to wire it in to get your car running. It won't prevent VTEC from working either.
If your car is OBD1, you can have the ecu reprogrammed to have a disabled KS.
Hit me up if you're looking to get this done..
Old Nov 25, 2005 | 01:33 PM
civhatch's Avatar
my car is obd1 but my motor is obd2 so would it still be the same??
Old Nov 25, 2005 | 08:28 PM
biotech0123's Avatar
Default Re: (civhatch)
got one here for free it you pay for shipping, got a p28 with hondata and I dont need it.. Just sitting here bout to relocated to the trash
Came off my b16
Old Nov 26, 2005 | 09:18 AM
civhatch's Avatar
would it work on my gsr motor, and will it still run right and pass emissions etc..?
Old Nov 26, 2005 | 10:45 AM
BigJ5's Avatar
No, you don't need the knock sensor, it's a safety device. As for emissions, I don;t know how they test them where your from. But normally you ave two choices here, idle and load test (at 3000rpm), or if your 4wd a 2stage idle (idle and no load at 3000 rpm), if your car knocks for either of these tests. You have something more to worry about than failing an emission test.
What tune are you using for this? that would be the most important question.
If your running a P30 (b16) or P72/3 (B18C gsr/itr i believe i always expletive up the numbers) then you will have a cel - code 23 - and thats it....and no retard on knock
Old Nov 27, 2005 | 09:05 PM
civhatch's Avatar
not really understandin what u mean by no retard on knock, and i plan on runnin a type r ecu because i am about to upgrade to a type r valve train
Old Nov 28, 2005 | 06:34 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigJ5 &raquo;</TD></TR><TR><TD CLASS="quote"> then you will have a cel - code 23 - and thats it....and no retard on knock</TD></TR></TABLE>
my car drove like **** when i had code 23. it was on a p13, it started fine, and idled fine, but it didn't sound right, and it was a lot slower.
Old Nov 28, 2005 | 12:55 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civhatch &raquo;</TD></TR><TR><TD CLASS="quote">not really understandin what u mean by no retard on knock, and i plan on runnin a type r ecu because i am about to upgrade to a type r valve train</TD></TR></TABLE>
If you didnt know, the knock sensor is a safetly sensor. What it does is pull timing back (aka retard timing) when the sensor detects 'knock' or 'detonation'. Over time serious knocking/detonation can crack your piston(s) or cylinder head. This becomes more apparent if you boost your engine, but for NA setups its not as serious.
The type-R ecu will look for the KS.
If you're engine is a B or H-series you can use any B or H knock series (mix or match) on any B/H VTEC engine...
jdmem205
Apr 1, 2013 04:10 AM
jdmdseries
Nov 16, 2007 03:46 PM
IA95civicDX
Aug 18, 2005 11:05 AM
