Quick: Gas/Temp Not Working
Old Nov 27, 2005 | 05:39 PM
93preludeh22's Avatar
Default Quick: Gas/Temp Not Working
95 Honda CX Hatch (CX Cluster works)
Put in a automatic cluster with a tach... it redlines at 7200 goes to 9k
Everything works except for the gas/temp gauges. Do I have to rewire something?
Thanks!
(I searched already...)
Anthony
Old Nov 28, 2005 | 05:33 PM
TTT. Thanks guys
Old Nov 29, 2005 | 12:41 PM
I don't want to run out of gas
Thanks
Old Dec 1, 2005 | 01:19 PM
Nothing?
Old Dec 1, 2005 | 02:04 PM
rainforest's Avatar
Default Re: (93preludeh22)
either there is a open in both of the wires very unlikly. or the gauge is not working proporly. because the pins dont cange in any of the obd1 civic clusters auto or manual. so no wiring is needed
Old Dec 1, 2005 | 05:12 PM
Default Re: (rainforest)
Thank you!
Old Dec 2, 2005 | 11:26 PM
kampucheakid's Avatar
this happened to me once... there are 3 screws in the back of the cluster that holds that gas/temp. part in.. well, i tightened it too hard and put in the wrong set of screws... i was told that "certain types" go in.. they have the bronze and silver screws.. that could be the problem ...good luck.
Old Dec 3, 2005 | 04:08 AM
If the wrong screw goes in then it doesn't work? Not properly grounded or what?
Thanks
eddie7978
Sep 4, 2018 08:44 AM
sf@rx7
Feb 17, 2006 07:42 PM
trooper0641
Sep 1, 2004 11:13 AM
ej1 pilot
Feb 10, 2004 03:56 PM
F120man
Dec 24, 2002 01:03 AM
