h22 swap exhaust headers...
Old 11-06-2005, 12:37 PM
SolAssassin's Avatar
Default h22 swap exhaust headers...
i'm in the process of swapping out a d16 for my newly acquired h22a1 with obd1. what kind of header / exh manifold should i use? will a prelude header bolt up to my cat? or will a prelude header with cat bolt up to my del sol's catback system? can i just use the entire wiring harness from the 'lude in the sol since they are both obd1?
Old 11-08-2005, 08:27 AM
Gillard82's Avatar
Default Re: h22 swap exhaust headers... (n2o_sol_h22)
i beleive that your flang from the down pipe to the exaust needs to be rotated a little bit to fit. not 100% sure tho
Old 11-08-2005, 09:26 AM
EK9-Stealth's Avatar
your dealing with a hybrid, so im not sure about pipeing. RMF, DTR, SMSP, HyTech, AN-R (no specific order) all make really nice and dyno proven headers. Bolt up the header your going to use with the cat, then have a muffler shop fill in whats between you ehuast can and your cat.
Old 11-08-2005, 10:58 AM
Gillard82's Avatar
Default Re: (EK9-Stealth)
i got a full HKS on my hatchlude sounds great, but fabracation is need becuse it is a hybride like EK9-Stealth stated. I am now possative that the flang need to be rotated to fit the down pipe. take it to a Lous exhaust, or other shop
preludepower01
05-18-2009 09:03 PM
94accordh22swap
07-14-2007 06:02 PM
Knightmare69
03-14-2006 12:49 PM
Broken Devil
10-03-2005 09:55 PM
SMSP
03-26-2002 11:33 AM
Quick Reply: h22 swap exhaust headers...
