SIR 1 problems after swap Wha happened ?
i had my motor rebuilt!
installed in the car now all water lines are new ect prety well everything outside the motor
i just filled it up with 4/1/2 liters of oil went to turn it over OIL leaking huge cannt figure out why.. its no the cam seal or the dissy i checked! i dont seem to understang where all this oil has gone and why it would leak like that i need HELP
-Rob-
-Rob-
DYNO-PRO
Location: SoCal I.E 909, CA, where we innovate not immitate
Re: SIR 1 problems after swap Wha happened ? (dubz01si)
ok long shot here but please make sure that the head gasket is not upside down
Re: SIR 1 problems after swap Wha happened ? (HOOKUPS)
really ? im assuming that this is a problem ill take off the head and flip it tomorrow! since its still new! you think that would make a difference ? cuz i didnt see any marking's ? its wet on the dissy side of the block not any ware else!
DYNO-PRO
ok usually wet on the dizzy side is a leak from above (v-cover, cam seal , ect also check the large allens on the side of the head for tightness
i just took of my valve cover
you know the allen key bolt's
the on on the side is okay on the dissy side.. there are 2 in line with the spark plugs at the top... the left side in front of engine beside the dissy is filled with oil & the other is dry ? problem ???
-Rob-
-Rob-
91crx-jace
04-22-2012 04:36 PM
BigDare23
13
10-15-2010 03:02 PM
