Those of you with a b18b in an eg...
I'm trying to finish my swap that I started before I went to Iraq and running into trouble. Could someone please post a pic of the vacuum lines on the manifold. The d15 motor had 2 vacuum ports on the throttle body and the B18 only has 1 port. Any help is greatly appreciated.
Re: Those of you with a b18b in an eg... (EG1834)
[IMG][/IMG]
I'm guessing that sensors #1 and #2 are the same?
[IMG][/IMG]
#3 is the vacuum port thats not on the B18 throttle body. Instead there's sensor #2 above.
[IMG][/IMG]
I understand that the vacuum line from #1 went to the port at #3 when the d15 was in there, but what I don't get is what to do with #1 and #2. Since they're the same, do I unplug #1, or #2, or what? Also, did you have any problems with the del sol radiator hose fitting your civic radiator?
prelude9999
10-08-2004 10:01 AM
