da h22
Old Nov 8, 2005 | 05:02 AM
Bo0sted4Do0r's Avatar
Default da h22
is there any company that make mounts for a h22 da???
Old Nov 8, 2005 | 06:40 AM
ALMXDUPINTEGRA's Avatar
Hasport
Old Nov 8, 2005 | 08:10 AM
Gillard82's Avatar
Default Re: (ALMXDUPINTEGRA)
i got avid they hold up, not as much as hasport
Old Nov 8, 2005 | 01:35 PM
h22apwrd95's Avatar
Default Re: da h22 (Bo0sted4Do0r)
You could also check out the H2B conversion brought to you by http://www.quartersportsdrag.com. It is an extremely well designed kit and has many benefits. There are a few posts on H-T involving the use of it. It may look costly, but compare it to the price of your swap, with axles, linkage set, mounts, cable to hydro conversion, it comes out even if not better in the end. Just throwing out a suggestion. This is the way I am going in my 94 coupe. Can't wait to get it done.
Mike
Old Nov 12, 2005 | 04:50 PM
is it easy to install.....?? and exactly how much is it
Old Nov 13, 2005 | 04:40 PM
AMS MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALMXDUPINTEGRA &raquo;</TD></TR><TR><TD CLASS="quote">Hasport</TD></TR></TABLE>
no one makes off the shelf H22 mounts to fit a DA integra!
Old Nov 13, 2005 | 06:30 PM
MoonScryer's Avatar
Place Racing is the only company that made DA H22 mounts, and they were not the best; the rear mount sucked for positioning.
The only possible way these days is to 1) H2B swap - make a new hood, but easy on the wallet, only add H22 2) use an EG/DC engine mount kit and redo the rear mount, and pray 3) make your own.
Old Nov 13, 2005 | 06:42 PM
ExplicitSpeed360's Avatar
Banned.
It would be pretty much the same as a crx h22 far as the how to mounts would be slightly different. Definetly not impossible probably doing one this winter!
turbogsr18
Mar 19, 2008 08:18 AM
jdm_cd5
Jun 6, 2007 03:19 PM
the DA in HONDA
Aug 24, 2004 08:31 PM
