b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles
Old 11-11-2005, 02:51 PM
doublejz's Avatar
Default b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles
well like the topic says i have
b16 in a 93 couple with skunk2 lowering springs and skunk2 camber kit.
It almost seems like the axles are an inch too short and keeps binding and blowing axles. I go through a set like ever 2 months. They bind in ever turn. I have tried pepboys, autozone and now I am on raxles one. Probably have about 100 miles on them and they are about shot. I left the 93 couple spindles on and I am using Del Sol Vtec axles. Anyone else have this problem or a solution???
Old 11-12-2005, 05:52 AM
doublejz's Avatar
Default Re: b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles (doublejz)
bump
Old 11-12-2005, 06:35 AM
Goinfasterthanu's Avatar
Have you checked the motor mounts?...they can be shot with out being ripped..
Old 11-12-2005, 10:13 AM
doublejz's Avatar
Default Re: (Goinfasterthanu)
just put in a new hasport drivers side, jdm **** passenger side and the rear one is till the same that came outta a 94 sol. *shrug*
Old 11-15-2005, 09:55 AM
doublejz's Avatar
Default Re: (doublejz)
one of my friends mentioned that he had to change the actual bracket on the block my the cam gears along with mount... anyone else do this?
EJ7CoUpE
10-16-2008 01:00 PM
teggytegteg
05-16-2004 11:41 PM
crxhybrid90
12-28-2003 12:00 PM
_Not_So_Nice_Guy
05-22-2003 06:48 AM
kangjin
02-07-2002 10:07 AM
Quick Reply: b16 + eg + neuspeed lowering springs + skunk2 camber kit = blowing axles
