ecu ?
Old Nov 29, 2005 | 02:32 PM
gsrHB's Avatar
Default ecu ?
iight i got a 96 civic HB and i engine swapped it with a 96-00 jdm b16, it is the original harness but i extented it so it can reach the passenger side with a p72 ecu and it bogs out around 4grand and wont acceurate, engine is runnning lean also, i took it to a eletric specialist and he told me the ecu is not for the engine and he told me that the p73 is would work, need help?
Old Nov 30, 2005 | 12:58 PM
Relic1's Avatar
you have a B16? or B18? (based on your user name)
P72 is a GSR
P73 is an ITR
I'd convert to OBD2b and pick up a P2T from a 99-00 SI or convert to OBD1 and run a P30.
which place in chicago did you take it to?
Old Nov 30, 2005 | 01:32 PM
98 Spec R's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
I'd convert to OBD2b and pick up a P2T from a 99-00 SI </TD></TR></TABLE>
Running the 99-00 Si computer requires CKF sensor on the oil pump which the OBDII JDM B16's dont have. Also, a VTEC oil pressure switch is required, which OBDII JDM VTEC Motors dont have. This would cost you a lot of money to upgrade the electronics on the motor and then get an ECU.
I would run a OBDI USDM or JDM P30 or chipped P28 and a jumper harness, unless you can find a OBDII JDM B16 computer. You can buy the harness and an ECU for your application from this website. http://www.locashracing.com
Old Dec 1, 2005 | 01:59 PM
gsrHB's Avatar
ii took the car to a buddy of mine he's an eletronic on cars and he told me that the p72 is the wrong ecu (engine is a JDM b16) and he told me the p73 will work on the engine but i need to pass emissions how would i do that?
k-oz
Engine Management and Tuning
Jul 17, 2011 10:42 PM
big_dong861
Nov 5, 2007 04:48 AM
pwrdbyDOHC
Jan 18, 2005 12:26 PM
BlVlW313
May 12, 2003 09:47 PM
sander
Apr 30, 2003 07:13 PM
