D16Z6 swap
D16Z6 swap
My name is Don
I own a 1995 Honda Civic Hatchback VX I.E. V-TechE
It has a D15Z1 Manual tranny
I have a D16Z6 engine,manual tranny,axles, and ECU.
I don't know if this will bolt right into my car.
If you know anything else i might need, can you please tell me.
Thanx
Modified by Donnyspeed at 6:08 PM 11/28/2005
Thanx
Re: D16Z6 swap (nitrared)
How long did it take you to do the swap
I have a two week period of time to do everything
Lable wires and hoses
Unbolt everything
Drop motor
Put new motor in and plug junk in.
Unbolt everything
Drop motor
Mr. Fuch-yu
Re: D16Z6 swap (Donnyspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donnyspeed »</TD></TR><TR><TD CLASS="quote">How long did it take you to do the swap
Unbolt everything
Drop motor
Put new motor in and plug junk in.</TD></TR></TABLE>With an experienced friend, sounds like about a day or two worth of work.
-Red
Unbolt everything
Drop motor
-Red
Mr. Fuch-yu
Re: (Donnyspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donnyspeed »</TD></TR><TR><TD CLASS="quote">thanks for the info guys
Will take pictures of the swap in progress and post them on my cardomain page. </TD></TR></TABLE>And then post them on here. If you do a good enough "how-to" article, it may become a sticky. Definitely not common, especially for a n00b.
-Red
-Red
Re: (Donnyspeed)
IIRC, the VX uses the 5-wire wideband o2 sensor. Meaning...you'll have to rewire that part of the VX harness for the 4-wire narrowband o2 sensor, or use the Z6's engine harness. Definately easier than the swap I did in my sig.
The two things to note is that you may have stuck axles (rusted into hubs), and most definately a problem with the 'bitch pin'. That's the pin holding the shift linkage to the tranny. 8mm bolt (or centerpunch with a lip machined into it) will do it. For the axles, swing the LCA's away, or just keep pounding them with a 4lb sledge like I had to. Also, make sure to get the motor mount bolts barely snug, then once they're all in, tighten them up (for no preload on rubber in mounts).
Mr. Fuch-yu
Re: (Donnyspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Donnyspeed »</TD></TR><TR><TD CLASS="quote">I don't think your alowed to post pictures on your thread. Said something in the rules i skimmed over.</TD></TR></TABLE>That means that you are not allowed to post pictures excessively and when not appropriate. Post pics in the correct place, such as a "how-to" article, and in a correct size, as big as you can without having to scroll sideways to see the whole thing. You just aren't suppost to do this in every post you make.
-Red
-Red
Re: (aallbbeerrtttttt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aallbbeerrtttttt »</TD></TR><TR><TD CLASS="quote">i'm in the process of doing the same swap, d16z6 + tranny into a vx, i'll let you guys know whats up</TD></TR></TABLE>
Write up a DIY. D16z6 into a Vx u should do it think about it.
How hard is it to do a swap i also have a vx and wanna swap in my z6 myself, but don't have any idea how to do it.
Unceasing Measure
Re: (LsBack!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsBack! »</TD></TR><TR><TD CLASS="quote">Write up a DIY. D16z6 into a Vx u should do it think about it.
How hard is it to do a swap i also have a vx and wanna swap in my z6 myself, but don't have any idea how to do it.</TD></TR></TABLE>
...You pull the old motor, put in the new motor and drive away. This is a direct replacement swap.
Can we be any more clear?
Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Can we be any more clear?</TD></TR></TABLE>
Yea actually since your so smart why do you help me. So just pull it and let all the wires rip out w/ it huh.... Thanks for the info
Mr. Fuch-yu
Re: (LsBack!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsBack! »</TD></TR><TR><TD CLASS="quote">Yea actually since your so smart why do you help me. So just pull it and let all the wires rip out w/ it huh.... Thanks for the info </TD></TR></TABLE>Smart-***. I like you already.
-Red
-Red
wheelerboy12
06-24-2013 11:33 AM
