what is the code for the 98 jap type-r
Old Jul 11, 2001 | 04:38 PM
CivicRacer's Avatar
New User
Default what is the code for the 98 jap type-r
Hi i need to know the engine code for the 98 japaneese type r.
Also im thinking about buying a (US) 98 type r motor but the guy said that the pistons were changed to 98 japan type-r. Is this a good thing or not.
Please help.
Old Jul 11, 2001 | 06:58 PM
92Si's Avatar
New User
Default Re: what is the code for the 98 jap type-r (CivicRacer)
I believe the engine stamp code is simply B18C for the JDM right? The USDM is B18C5. If the motor you are purchasing has JDM R pistons, it should have roughly .5 /point more compression. This can definitely be a good thing for an all motor application. If you want to go higher or lower, you can change your head gasket or use a B16 head (more chamber volume). Good luck HTH.
Rich
Old Jul 12, 2001 | 05:06 AM
TypeR0207's Avatar
Default Re: what is the code for the 98 jap type-r (92Si)
Yes, just B18C.
The only way to tell is to open the head, and look at the pistons and cams .....
Old Jul 12, 2001 | 05:09 AM
Trey's Avatar
25 Year Member
Default Re: what is the code for the 98 jap type-r (TypeR0207)
B18c Spec R is the 96-01 JDM version.....
Old Jul 12, 2001 | 08:51 AM
killingtime's Avatar
Default Re: what is the code for the 98 jap type-r (Trey)
There is a difference between 96 and 98 spec, with 98 being a slight improvement over 96.
Demian
SilvaEK9
Jan 27, 2014 08:40 AM
HATCHingMN
May 24, 2005 09:14 AM
BudMan
Dec 16, 2004 06:03 PM
uc0083
Feb 28, 2002 07:51 PM
