H22A in 99 Integra Help!
Old Aug 3, 2001 | 08:40 PM
Babybluegsr92's Avatar
Default H22A in 99 Integra Help!
I was wondering what i need to do to swap a h22a into a 99 Gs-R ObdII do i just need a H22a vtec with obd2 and it just bolts in with new mounts?
-joe
Old Aug 4, 2001 | 12:17 AM
B16A1-EF9's Avatar
Default Re: H22A in 99 Integra Help! (Babybluegsr92)
There may be some wiring involved. Use a good urethane mount kit, and buy an H22 that is 0bd2...this will make the swap alot easier!
Old Aug 4, 2001 | 12:56 AM
i was talking to someone and they said you cant retain your power sterring is that true with a h22a swap into a 99 gsr?
joe
Old Aug 5, 2001 | 10:01 AM
H22CIVIC's Avatar
New User
Easiest way for that swap would be to use your GSR harness on the H22. And use your GSR computer. The GSR computers run the H22's great!!!! The only that will be left out with the GSR computer is the EGR system on the H22. No big deal!!
Old Aug 6, 2001 | 01:50 PM
EVOCELICA's Avatar
New User
Default Re: H22A in 99 Integra Help! (H22CIVIC)
**** the EGR just block that **** off
Old Aug 6, 2001 | 08:53 PM
accordking's Avatar
Default Re: H22A in 99 Integra Help! (EVOCELICA)
Use the Hasport Civic H22 kit 92-95 Civic and it will also fit the 94-00 Integra as well.
My best recommendation is to retain your stock wiring harness and just lengthen the alternator wiring.
alwaysbroke
Jul 23, 2015 02:41 AM
h22aftw
Mar 21, 2007 02:41 PM
LX4SI2NV
Dec 27, 2002 12:28 AM
ace1875
Dec 15, 2002 08:30 AM
