b16 sir2 swap into 5th generation civic ex
I am planning on swapping a b16 sir2 into civic ex 5th generation. What wire harness do I use since the JDM harness that came with the setup is useless? What parts do I need in the scenario above?
Also, since the throttle body does not contain an external map sensor (built into t-body), how do I work around this ? How about if I was to go with a ITR throttle body?
Anybody have any help or suggestions ?
Guest
Posts: n/a
Re: b16 sir2 swap into 5th generation civic ex (KayOs)
First off, you should have searched this topic, I'm sure there's hundreds of posts on this.
Since you didn't here's some answers.
1- Use you EX harness and add the knock sensor wires or go buy a P30 (USDM delSol DOHC VTEC) harness.
2- Get a 94-95 T-body off a LS or GSR. OR, you can use the 98+ ITR T-body.
roro1
09-27-2013 10:44 PM
