B18B HEAD HELP!!!!!!!
Old Jul 20, 2001 | 10:08 PM
-VengeanceRacing-92DA9's Avatar
New User
Default B18B HEAD HELP!!!!!!!
I got a 1992 Acura integra RS, I got the Engine that came with the car.....
I just ordered a B18B Head from a 1997 Acura Integra...... I got a few questions....
I want to make the B18B head crazy Fast, heres what I need help with all BTW :: I am going to be sqeezing 80 Shot ::
Will 94+ GS-R Pistons/Rods, Oil Pump work with the head?
Will 92 Integra Intake Manifold, Throttle Body, And Alternator Work on the 97 B18B head?
Will TYPE-R Valve springs/retainers work?
Will 94+ GS-R Valve springs / retainers work?
What Should I do to the Head to make it have some good highend?
Im havin some problem here, I got the head, Imma throw some CAMS on it, but thats about all i know......Just need some tek Help here, thanks to all that reply....thanks yall
New User
Default Re: B18B HEAD HELP!!!!!!! (-VengeanceRacing-92DA9)
Ohhhhh yeah and the Head is from a 1997 ACURA INTEGRA LS
Old Jul 22, 2001 | 01:59 PM
DaveF's Avatar
b-series vtec oil pump and pistons will fit on the b18a/b's--the rods are a different a different length,so they won't work.i'd say if your gonna get new pistons,get a set of forged je's or endyn's,which will hold up to n20 a lot better.i would use a 95+ ls manifold..i noticed the runners are shorter and of a bigger diameter on the b18b's and a 92 throttle body will fit a 95+intake manifold. no,none of the b series vtec valvetrain will fit on a b18a/b.a good port and polish should give you a good top end,but you need a cam that will actually make power at higher revs.
Old Jul 22, 2001 | 06:55 PM
raene's Avatar
Default Re: B18B HEAD HELP!!!!!!! (turboDA)
The valvetrain will not fit, no, but you can bolt on the head and make an LS/VTEC.
Old Jul 22, 2001 | 10:26 PM
clockworks's Avatar
Are you getting the B18B intake manifold with it? If so, use that, it flows better than the B18A one.
Greg
Old Jul 23, 2001 | 01:02 PM
New User
Yeah imma be gettin all the parts from the guys old LS
Intake Manifold, alternator, throttle body everything.....
While everything is off, can anyone suggest anything to do with the head and intake manifold, throttle body? While its off, I am going to be sprayin 100 shots so I need a strong engine....
I am going to be gettin Stainless Steel Valves, cause I heard those would help the engine, the stock ones just break up the valve train.....
Someone said the stock B18A1 rods for the bottom block are strong enough to handle up to 350 HP....if this is true, Then should i still get the GS-R rods, ? Whats the difference rods would make for my new motor? Just curious....I know the GS-R Oil pump will make the OIL PRESS higher, which will in turn help out more......lemme know all.....thanks
boostedb20z
Feb 20, 2008 06:09 PM
kennybintegra
Aug 27, 2006 09:11 PM
redEFnine
Jul 9, 2003 10:35 PM
HaTcH_BmX
Jun 15, 2003 06:40 PM
The Rob
Jun 18, 2002 11:30 AM
