B16b questions...
just switch your b16a distributor, exhaust manifold/header (if running two 02, or reuse the the b16b), use your injectors, alternator, add your b16a coolant sensor in the back of the block....and reuse your old PR3 or PW0, and get it chipped to mugen specs and you be fine...
no need to do obd0 to obdii....as far as JDM motors 96+ are OBDII but only plug wise, the sensors and programming is still like obdI
T_Rex
Northwest (Sales)
Mar 5, 2007 02:55 PM
