h22 vs. b20 vtec
Old Jul 8, 2001 | 02:29 PM
Turbohatch's Avatar
New User
Default h22 vs. b20 vtec
what are the cost, hp, and install difference???
Old Jul 8, 2001 | 04:13 PM
93delsol's Avatar
New User
Default Re: h22 vs. b20 vtec (Turbohatch)
costs for the H22 will be more, because you will need a mounting kit. They go for around 400-500 dollars. I believe that the H22 will also cost more, but i'm not sure how much more. The H22 will have more power. B20 will drop right in, but with the H22 you'll have to use custom mounts, or get someone that likes to weld . Also you have to convert the shifter to cable instead of shift linkage (it's still a hydro tranny though). Everyone talks alot about understeer, but after talking to some people that have the H22 swap, they say it's not as bad as everyone makes it seem. The b20 weighs around 300 pounds, while the h22 weighs around 380. If you got a carbon fiber hood, you could lighten the front by about 25 pounds. Also if you don't get any sway bars in the front, and get the big ITR rear sway bar, i heard it helps alot. Hopefully someone that has done this swap can reply, because i'm somewhat clueless on this topic
97spooncivic
Feb 8, 2010 04:44 PM
Honda-Hooligan
Feb 15, 2004 12:22 PM
South Bay Surfer
31
Mar 18, 2003 07:46 PM
89B16HBSBETTERHALF
17
Sep 3, 2002 08:26 PM
lstec2b
May 15, 2002 01:57 PM
