What to do with axles?
Old Jul 9, 2001 | 11:24 AM
91crxer's Avatar
New User
Default What to do with axles?----and replacement parts?
If I buy 90-93 integra axles, do I need to do anything to them other than remove the little ring on the end? For a
JDM 1st gen b16a into a 91 CRX SI with HASPORT mounts? Also, I guess I am not real clear as to what engine I am
able to swap parts from...example--plug wires, timing belt, cap-rotor, that type of thing...IS THERE ONE year and model
US engine I can swap from?
Thanks and drive safe...
[Modified by 91crxer, 8:25 PM 7/9/2001]
Old Jul 9, 2001 | 01:18 PM
91sifreak's Avatar
New User
Default Re: What to do with axles?----and replacement parts? (91crxer)
I have this same setup, most of the engine parts will come off a 93-97 delsol Si dohc, clutch is a 90-93 integra, and alot of type-r parts intake manifolds and throttle bodies, it really depends on the parts but they will come from those cars, except the upper radiator hose to a stock crx si radiator. That you will just find a hose the looks that it will fit and cut it to size. Hope this helps, and the axles will be off a 90-93 teg non-abs 5sp, all you have to do on the Si is that ring and make sure to not pull them apart. Have fun with the swap, and yes it is quite quick.
Old Jul 9, 2001 | 01:54 PM
sgT's Avatar
sgT
Default Re: What to do with axles?----and replacement parts? (91sifreak)
Get axles and intermediate shaft from a 94+ integra or del sol with b16a
or 99+ si. Then remove the outer ring from both axles.
jayhelladum
Sep 25, 2008 09:27 AM
botlebruiser
Apr 4, 2006 09:03 PM
B_Something
Aug 8, 2004 02:52 PM
QWKPHKR
Jul 11, 2002 04:03 PM
89sir-9
Nov 23, 2001 08:29 PM
