which driver's side mount??
Old Jul 5, 2001 | 11:06 PM
paulzy's Avatar
Default which driver's side mount??
Hey guys....which driver's side mount do I use for a b18a1(90-93) into a EG chassis? I was thinking that I could probably use the stock 92-94(not 95)mount, since the bolt openings are not parallel like the 95 EX and 94+ integras....let me know guys....
Old Jul 8, 2001 | 04:56 PM
Senses Fail y0!'s Avatar
I should know better
Default Re: which driver's side mount?? (Slow_ass_4dr)
get the mount from a DelSol VTEC. all the mounts would work actually if you need any other. also HASport sells a whole kit. and you could email them and ask to make it sure itd work with your specific set up. http://www.HASport.com
Old Jul 10, 2001 | 08:43 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
90-93 b18a driver side.
racerpat94
Welding / Fabrication
Feb 28, 2007 07:31 AM
B18aHatch
Aug 19, 2005 06:50 PM
sloweredcivic
May 15, 2005 09:01 PM
lsvtec101
May 15, 2004 06:35 PM
92civeg
14
Feb 20, 2004 09:35 AM
