slower than before
Old Jul 17, 2001 | 08:31 PM
WONG FRIED RICE's Avatar
Default slower than before
i timed my car before and i ran a 15.3 w/ i/h/e and with both sprockets advanced 2 degrees, and a untuned sfc-vtec controller. Just last week i timed it again...and ran a 15.9...but i also had removed the exhaust in favor of a factory setup (not willingly, but i live in san francisco...where the police are really up tite about things like that), and i set the cam sprockets differently...intake advanced 2 degrees, and exhaust retarded 2 degrees, but i also put in a random tech hi-flo cat, (because my old one was really messed up). I thought i would have run a similar time...does the exhaust really make that much of a difference? Also i have some funny idling problems at the time of the run...and still do...is the slower time because of the exhaust??
Old Jul 17, 2001 | 08:37 PM
5gen-hybrid's Avatar
New User
Default Re: slower than before (JDMB16ACRX)
well try setting everything back to where you had it before (except of course the exhaust) then make another run. it's hard to tell what did it when you have changed a few things. could be the timing,or the idling problem also.
Old Jul 17, 2001 | 08:46 PM
Default Re: slower than before (hybridxcivic)
hmm...basically everything was the same...besides the exhaust, and the cam gear settings. So do you think it could be the idle problem? or the cam gear settings?
Old Jul 17, 2001 | 09:05 PM
3.3.3's Avatar
its probably the exhaust....youre more restricted now...i ran about .4 worse without my cat-back 2.5 sys. try taking off the muffler when you run.
Old Jul 17, 2001 | 09:54 PM
New User
there is only one way to find out. fix the idle problem and set the cam gears back to what you had before then run it again.your not going to gain almost a full second by adding a less restictive exhaust on a n/a honda. if that were the cas there would be low 14 second civic ex's that only have i/h/e..... not going to happen.
Old Jul 18, 2001 | 01:47 AM
raene's Avatar
What kind of idling problems?
Old Jul 18, 2001 | 08:37 AM
Speed PHreak's Avatar
Default Re: slower than before (raeneshadow)
Wiseman says: "Change only one thing at a time.....that way if somethings wrong you know what to fix"
~steven
Old Jul 18, 2001 | 09:41 AM
when i first start the car the rpms jump around from like 1400-1600 (cold). Then when the car warms up...the idle jumps around from 700-900 consistantly...no steady idle...the car sort of feels shakey when it jumps around.
Old Jul 18, 2001 | 09:50 AM
Big James's Avatar
New User
It seems like 50% of the hybrids have that same problem with idle. yet, no one knows what the hell it is.
Old Jul 18, 2001 | 10:48 AM
raene's Avatar
DEFINITELY sounds like you have a vacuum leak at idle. I'd check your vacuum lines and fittings for tightness and/or cracks and abrasions in the hoses.
I hope that solves something...
P.S. Not ALL B16As have idle problems. Mine idles just fine now, thank you .
Old Jul 19, 2001 | 10:45 AM
also i forgot to add that besides the idle problem...there's slight hesitation once in awhile between 2-2500 rpms when i step on the gas. I just changed the o2 sensor...so i don't believe its that. But i'll check that vacuum idea out...thanx!
Old Jul 19, 2001 | 12:45 PM
raene's Avatar
Try unplugging your O2 sensors. That cured my hesitation problem .
jordan00711
Acura TSX
May 12, 2009 02:53 PM
acidburn2k2
Jan 7, 2006 01:03 PM
1hotcivicSi
Acura TL, RL & ZDX
Mar 31, 2004 11:39 PM
