bad corrosion around spark plug...HELP!
New User
ok as i posted yesterday i had water in the spark plug cylinders...i gotten most of the water out of that area..now i got another problem...bad corrosion and rust around the several of the spark plugs and im aving trouble cleaning them out...im afraid of the corrosion particles falling into the combustion chamber...what should i do...please tell me i dont have to tear down the whole motor...should i invert the motor on a motor stand and remove the plugs upside down??...thanks for any help...
New User
Re: bad corrosion around spark plug...HELP! (wuhungsixxx)
Try and use a wet-vac..and suck anyloose stuff out.....or dampen a rag and stick it down there, use a screwdriver to try and wipe some of the particals away. Just a couple of ideas, dont know if they will work... I would reccomend just buy new plugs why you are at it, REMEMBER to gp them......
Have fun and drive safe........
New User
Re: bad corrosion around spark plug...HELP! (91crxer)
so should i be afraid if any corrosion falls into the combustion chamber?...i tried to use a paper towels and a metal skewer for BBQ to scrape as much as i could off of it but there is still alot of gunk corrosion stuff around it
wuhungsixxx
07-17-2001 12:17 PM
