LS Engine for $650?
Old Jul 9, 2001 | 03:36 PM
DamnSlowCivic's Avatar
New User
Default LS Engine for $650?
There's a 94+ Teg LS engine (just a basic engine, not a complete swap) @ 27000 miles for $650 for sale at a local junkyard. Just wondering if it's a good price or not? And anyone knows how much more it'll be for everything else if I could find it? Or anyone have EVERYTHING for a complete LS or LS/VTEC swap minus the engine?
Old Jul 10, 2001 | 04:38 AM
eg6ajk's Avatar
Default Re: LS Engine for $650? (DamnSlowCivic)
thats the usual going price $500-800 is usually right...
Old Jul 10, 2001 | 06:49 AM
92Si's Avatar
New User
Default Re: LS Engine for $650? (eg6ajk)
That is a decent price. If you plan on using the transmission, that will definitely get your LS/VTEC project started. The throttle body and distributor should be riggable/usable & the low miles might not warrant an overbore unless you really feel the need. Good luck with the project.
Old Jul 10, 2001 | 08:37 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i paid $700 for my 94 b18b1. that sounds right...if you are worried about the health, see if you can compression test it. also, give it a good visual inspection. if you get the tranny separate, you should try and get the gsr tranny because it is better for all motor applications. if you are going to put a turbo later, you will probably want the ls tranny for the longer gears.
Old Jul 10, 2001 | 10:50 AM
New User
Default thanks all
Thanks for all the replies. I want to do either an LS/VTEC + turbo or LS + turbo. Now that I could get the engine, looking for a tranny right now. What other parts do I need if I'm going to go pick up parts by parts like this? Or would it better just to wait for a complete swap? I'm dropping all this in an EG by the way.
Old Jul 14, 2001 | 10:04 AM
hydroflip's Avatar
Default Re: thanks all (DamnSlowCivic)
wow....how come whenever i find a ls engine its always 2,700???? where can i find a good engine for as cheap as you guys are saying....i always go to sohfast.com to get the engines....thanx for the help!
All Motor EH2
Dec 12, 2004 06:25 PM
gribbs
Apr 13, 2003 02:03 PM
turbohf
13
May 10, 2002 10:28 AM
Bnjmn
Feb 5, 2002 04:02 PM
91int
Jan 18, 2002 11:50 AM
