code 22???
Old Jul 7, 2001 | 05:05 PM
prjctCIVIC's Avatar
Default code 22???
how do i fix this code 22???? its happening on my gsr motor..any help is appreciated, thanks
Old Jul 7, 2001 | 09:32 PM
Blown90hatcH's Avatar
Default Re: code 22??? (prjctCIVIC)
Vtec Pressure switch. The little sensor below the vtec solenoid. Check to make sure that the wiring is okay.....if this is a hybrid. If this is a stock gsr, then check the sensor. Pull the plug of the sensor and with an ohmeter, probe the two pins of the switch. There should be continuity....it none =bad switch. Try that and let us know
JAson
Old Jul 8, 2001 | 07:45 PM
prjctCIVIC's Avatar
Default Re: code 22??? (Blown90hatcH)
sorry to mention this is a hybrid civic BTW...do you happen to have then pinouts for a 92 civic si w/ a 97 gsr running a jdm 94 gsr ecu....thaks for your help
Old Jul 9, 2001 | 04:37 PM
I2secRex's Avatar
New User
Default Check your oil level
It's a common occurance for a code 22 to come up if you're a quart low and going around a hard corner / accellerating.
-Kevin
Old Jul 9, 2001 | 06:49 PM
prjctCIVIC's Avatar
well i got the light off, but dont know what i did, just messed with the wires and resetted the ecu and started it up...NO CEL, yes!!! thanks for yours guys info and help...
LS Turbo300
Feb 27, 2014 04:50 AM
LS Turbo300
Aug 23, 2012 04:47 AM
brandynEG
Jun 28, 2012 06:23 PM
hondaman156
Nov 12, 2006 06:11 PM
89Civic
Jun 10, 2002 12:16 PM
