water around the spark plugs...HELP!!
New User
hey check this out guys...well im getting ready to do the b18c swap into my crx...iv had the motor chillin outside under a tarp for a few months now...i had to move it outta my garage cuz pops was gettin pist about it takin too much room up...anyways i thught it would be aite with the tarp over it...i went to pull the plug wires out and i noticed it had water on the tip that was alil brown from corrosion...i freaked out...i was like aww shiz...i looked at three of the four plugs had a lil water around it...one acutually had a puddle...i tryed to dry it out as much as i could there is still a lil water left but im having a hard time getting to it...how should i dry it up?...and please tell me my motor is ok....please!!...
New User
Re: water around the spark plugs...HELP!! (wuhungsixxx)
You should be fine just get a compressor and blow the water out. Also make sure to change your plugs and wires. I had a ZC and I would hose it down when it would get real dirty, water would fill in where the spark plug wires would go, I would just blow it out with a compressor and it would run fine just make sure you get it bone dry because it will misfire if there is water around the plugs
