Quick axle question for B16 swap .....
Into a 4g Civic (EF).
If I just get '90-'91 Teg axles, then all I have to do is get the same year Intermediate shaft, and I'll have no axle worries, right?
What did you guys do??
New User
Re: Quick axle question for B16 swap ..... (TypeR0207)
NO!!!!!Depends on which tranny....YOu can check Erick Bauer's site or else I think HASPort.com has 411 on which axles and int. shaft....
Re: Quick axle question for B16 swap ..... (Red Civic T)
I did, but I beleive that the HASport site has the opposite, they tell you which axle to use based on which intermediate shaft you already have.
I remember someone else saying on the board that the way to clear up the intermediate shaft question is to just use the same one that you have the axles for.
New User
My read on it was that if you have a Y1 tranny you use an 86-89 int shaft, and for S1/J1 tranny 90-93 int shaft (from teg). It should then tell you which axles to use with that....Hopefully you have S1 and then you just use 90-93 hookup for both.
Don't be like me and forget to tell wrecking yard that you need for MANUAL, not AUTOMATIC which look beefier but are like o.5 inch too long....
JustAnotherRex
01-09-2009 05:29 PM
crexer
27
12-22-2004 10:39 PM
type Gendy
13
02-03-2003 10:51 PM
TypeR0207
07-28-2001 02:03 PM
