need info
Old Jul 3, 2001 | 03:12 AM
TriCkSpEeD's Avatar
New User
Default need info
need help doing my swap I'm gonna swap a 94 GSR motor in my 90 integra ls what wire i need and which ecu will fit
Old Jul 4, 2001 | 06:05 AM
eg6ajk's Avatar
Default Re: need info (typeR)
few ways:
obdI to non-obd harness conversion, + add vtec, knock sensor, secondary (IAB) to your old harness
or
use a PR3/PWO non-obd ecu(plugs up), add the vtec (3x wires), knock to your harness, and get a Skunk2 manifold...becuase b16a ecu do not activate the the second stage of the (dual manifold)...reuse your injectors, add a b16a (1st gen) distributor....and dual 02 sensors....just as if it were a 1st gen b16a
also by going with a skunk2 intake you will gain some power .....
Glowicki
20
Oct 8, 2013 04:26 AM
Rok_Stok
12
Mar 1, 2009 02:37 PM
b16std
Feb 15, 2005 01:31 PM
.ShawnD.
May 5, 2004 07:22 AM
LD_EGSICK
20
Feb 4, 2003 07:47 PM
