Converting 00 Ex to 97 JDM B18c
New User
I am in the process of purchasing a JDM b18c swap...is there any extra parts that I will need to buy to have the swap completed...also any need to know info that I should be aware of..thanks
1 Post
Re: Converting 00 Ex to 97 JDM B18c (SupaFlyGuy)
There is a bunch of fun stuff that you're gonna run into. I just did the same swap myself basically (97 USDM B18C1 into 00 DX). You will have to rewire the distributor seeing as the plugs don't match up. You will also need to get an ECU jumper to run an OBD II or an OBD I computer. That's basically it. But you might need some more help.
Let me know. I can email you the directions that I've recieved about the distributor.
Late..
Craig.
Late..
Craig.
Thor294
01-16-2015 01:29 PM
