B16a head and B18c block....
Thanks sgT.
Is there any modification needed for these conrods to fit? And what else should I consider doing since it's running such high compression?
TIA
TIA
Only mod is to have them pressed on. Only LS's require shaving of the rod. Run 92 octane, and get it tuned. You can also sand down the sharp edges to lower compression and reduce detonation.
pacienzavtec
Sep 14, 2002 08:32 PM
