Questions about my swap
i'm swapping a b16a2 out of a 99si into my 92 cx hatch. the hatch currently has a d16z6 in it.
I'm wondering if 1) there are any special wiring things i'll have to do (i'm going to be using the ecu and harness from the 99si), 2) if i can just use the mounts from the 99si motor, 3) if i have to do anything special with the tranny (i'm using the hydro from the 99), 4) which header, cat, and intake do i run, 5) where do i put the second o2 sensor (i think the 99 has 2), and 5) anything i should look out for/be aware of
i have access to whatever i need of the 99 si, and also obviously have access to anything that goes into a d16z6 swap, so just let me know.
thanks a lot for the help
adam
adam
harvey121
13
01-05-2012 08:55 AM
