Can anyone help???
Old Jul 16, 2003 | 10:40 AM
redlinegsr's Avatar
Default Can anyone help???
Is there any way to bypass, rewire, or somehow get the check engine light off throwing a code for no knock sensor due to the fact I have an lsvtec setup with gsr harness. I cant pass inspection with the light on so I need help quick!!!
Old Jul 16, 2003 | 11:54 AM
Turbogixxer's Avatar
Default Re: Can anyone help??? (redlinegsr)
Someone wired a resister to it (i think 13k) and they said that the code went away. I will search and see.
Old Jul 21, 2003 | 09:52 PM
Esoterikos's Avatar
Default Re: Can anyone help??? (turbogixxer)
ummm...i pulled the gauge pod out and removed the light, but i've never had to pass a smog test.
Old Jul 21, 2003 | 09:59 PM
Newman's Avatar
New User
Default Re: Can anyone help??? (S8P-tuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S8P-tuner &raquo;</TD></TR><TR><TD CLASS="quote">ummm...i pulled the gauge pod out and removed the light, but i've never had to pass a smog test.</TD></TR></TABLE>
Only problem there is that the ECU will still throw the KS code and when it does, it makes the engine run like crap, makes it hesitate, and then runs in "limp" mode. The 10K OHM resistor does work, as I did it on a customer's car (per his request) and grounded it to the chassis. No KS cel's for over a month now.
Old Jul 22, 2003 | 01:40 PM
Audipwr1's Avatar
Default Re: Can anyone help??? (Newman)
why not mount a knock sensor?
eg6b16Atwo
Feb 25, 2007 04:11 PM
skunk2415
Nov 3, 2006 12:48 AM
vega_ROCKS
Jun 25, 2005 01:12 AM
Xanadu
Sep 23, 2004 11:11 AM
