anyone using a B16A's ECU with a B18C1??
for a b18c1 build to ITR spec,
this would put VTEC engegement at the right point for a single stage intake manifold (ITR or skunk2) and would feature a slightly higher rev limiter.
it may require some extra fuel but then again it might not. nobody seems to knwo how ECUs work anyway.
any experiences?
-s
any experiences?
-s
Re: anyone using a B16A's ECU with a B18C1?? (EG8steve)
you can use a B16 ecu , just make sure you reset the vtec engagment accordingly and also get a FPR set it at 48ish psi and you'll be good to go.
